MU not moving properly
linlinoful vor 3 Jahren in General Questions • aktualisiert von Support vor 3 Jahren • 1
MU is sitting on transport surface. Moving up and down is possible but moving to the left and right does not cause the MU to follow (see pictures). Any ideas?
Image 974
Image 975
You should use a "Parent Drive" or the new Guided Transport Surface. This is due to limitations in combining Kimeatic Drives with Physical based TransportSurfaces. Please check the Demo model for Moving TransportSurfaces and the documentation here:
https://doc.realvirtual.io/components-and-scripts/motion/transportsurface#transport-surfaces-and-unity-physics
and if you would like to use Guided Tranport Surfaces here:
https://doc.realvirtual.io/components-and-scripts/motion/guided-transport
