Guided MUs not rotating on Guided transports in Unity 6
Alexander Andreasson vor 2 Jahren in realvirtual.io Starter and Professional • aktualisiert von Support vor 2 Jahren • 4
Youtube video
After upgrading to Unity 6 LTS, the MUs are no longer rotating on turn surfaces while following a Guided Transport, however if I go back to unity 2022 it is working as intended, what could be causing this?
Hi Alexander,
we are checking this - we know that there has been an issue with the new Unity 6 Physics. Will keep you updated.
Hi Alexander,
which realvirtual version do you use in Unity6?
Christin
Hello! I'm using the latest LTS, 6000.0.34f1
Image 1309
Do you use RealVirtual 2022 or RealVirtual 6? Our 2022 guided transport may not work properly in Unity 6 due to physics engine changes.
Christin
