Found bug in MeasureRaycast.cs
Luke 1 year ago in realvirtual.io Starter and Professional • updated by Support 1 year ago • 2
I found and fixed a bug in the MeasureRaycast.cs script. Originally the "Raycast to Layer" setting would not work. I replaced the following lines.
layermask |= (1 << LayerMask.NameToLayer("RayCastToLayer"));
layermask = ~layermask;
With this
layermask = 1 << LayerMask.NameToLayer(RayCastToLayer);
And it seems to work now. Just posting for others in case they have the same issue.
You are right - thanks a lot for reporting. Will be fixed in next release.
