PLC SIM Advanced 6.0 Windows 11 Realvirutal Unity 6
OkrutnySCD vor 1 vor einem Jahr in realvirtual.io Starter and Professional • aktualisiert von Support vor 12 Monaten • 5
I have problem with PLCSIM Advanced (Pro). I tried import signal but everytime i have this message.
Image 1394
When I tried start manual PLCSimAdvancedCoupler I have this
Image 1395
I copty to correctly location because I use this in version 2022 but now I can't use this.
will are checking it later on this evening. You can also try using S7TCPIP interface with PLCSIMAdvanced
Can you please turn debug mode on and send me the full Unity Console log:
Image 1399
After you did this you should see in the log how to start it manually. Please use a windows console and start it for example like this in my test setup:
E:/realvirtual6/game4automation/PLCSimAdvanced/PLCSimAdvancedCoupler/PLCSimAdvancedCoupler/bin/Debug/PLCSimAdvancedCoupler.exe SIMIT_S71500_NurVar_1 10 -1 debug all
You should see something like this in the windows console. Please also send me your full console output which should begin like this:
Start PLCSimAdvanced Coupler V3256 [SIMIT_S71500_NurVar_1] with Cycle ms 10
Start Open Interface
Create Interface
We have an improved version of the interface. If it still not works on your side let me kow and I can get you access. It will be included in next release.
Solution will be part of 6.0.7 which is going to be released in next days.
