S7 connection - get_gameObject can only be called from the main thread.
efr vor 10 Monaten in realvirtual.io Starter and Professional • aktualisiert von Support vor 10 Monaten • 3
When trying to make an S7 connection (new empty scene) in the realvirtual.IO starter kit I have following issue.
The connection is OK and running in Scene mode, but once in Game mode, I see I have following error:
Connection failed: get_gameObject can only be called from the main thread.
Constructors and field initializers will be executed from the loading thread when loading a scene.
Don't use this function in the constructor or field initializers, instead move initialization code to the Awake or Start function.
In the connection view of TIA portal I see a lot of connection active.
Does anyone has any advise on how to solve this?
Unity version
Image 1433
siemens CPU 1515-2-PN
Image 1429
Image 1430
Image 1431
Image 1432
Please try changin in line 779 this:
if (connectionstatus == 0)
int ExecTime = Client.ExecTime();
// Use ThreadStatus for thread-safe logging (no Unity object access from background thread)
ThreadStatus = "S7 interface connected - time: " + ExecTime.ToString() + " ms";
Much better!
Never would have find this.
Thank you for your quick answer.
