Just a note about the Mod bus documentation.
Modbus is either Master/Slave OR Client /Server.. This terms should not be mixed.
Client means Master Server means slave. Modbus has made this confusing!
You say "Currently realvirtual.io can be only used as a Modbus master. Client support will be added in one of the next releases." This does not make sense. Client is the Master.
https://www.prosoft-technology.com/insights/technology-focus/Crash-Course-Client-Server-Master-Slave
I think what you have is server support or slave (passive) and it is driven by an outside Master or Client.
Has the client been added? ( its a wee bit over 2 months) I see you are using easymodbus so hopefully it shouldn't be that problematic. It would be extremely useful as most will use G4A as a client.
Thanks for any update on this.
Thanks. Your on-line docs should be changed to reflect that it is now included and does not to be loaded separately.
The more I am getting into the software, the more impressed I am. Great work!
On a side note the docs imply EthernetIP is included in the starter edition. (doesn't say only in Professional)
I take it that it is not included.
Here is the actual directive from Modbus about names conventions:
https://modbus.org/docs/Client-ServerPR-07-2020-final.docx.pdf
