Thank you Thomas. I look forward to your findings.
In addition, I'm experiencing huge lags because of the communications working in Windows 11 (removing the commented line 133 to allow communication with the Kepserverex):
Image 922
It should work like this (performance of the same project working in Windows 10):
Image 923
Any idea?
Thank you in advance!
Dear Thomas,
All good! Thank you for your help!
Kind regards,
Ernesto
I purchased for Professional 2020 (the only available on the asset store) and now I don't know how to upgrade to professional 2021.
Please, let me know how to upgrade it.
Dear Thomas,
I did purchase it on May 6 2022 from Unity asset store.
Hi Thomas,
Thank you for the quick response.
There is not an update from Digital Twin Prosessional 2020 to 2021?
Kind regards,
Ernesto
Hi!
I said by email, the last update of the OPCUA_Interface component is running fine when the communication is established remotely, I mean, when the server is on one PC and the Client is on another PC, for example.
However, when I tried to run the server and the Unity client on the same PC, I get that the host cannot be resolved:
No matter if I try to connect using the localhost endpoint or other available endpoint.
Any idea of what I'm missing?
Thank you in advance.
I replaced the last OPCUA_Interface.cs script you sent me via email and now seems to work fine!!!
Again, thank you for your support!
Thank you very much!
I'll look forward to your update.
As in the last thread, I'm still stacked connecting with the OPC server...
Following your instructions, I did replace the OPCUA_Interface.cs file but, unfortunately, I'm not getting a connection.
In the following image you can see the error I'm getting.
Am I missing something?
Thank you again for the help.
Kind regards,
I did replace the OPCUA_Interface.cs file but, unfortunately, I'm not getting connection.
Kind regards,
