Inability to connect Omron plc via enternetip
Soncon 4 years ago in realvirtual.io Community • updated by Support 3 years ago • 4
Dear
When connecting Omron PLC NX1P2 via enternetip, set the above parameters, then click the TEST CONNECT button, the connection fails, the computer can ping through 192.168.1.1, about the parameter path setting, it is not clear how to set, have tried in many ways, I can't even make a connection.
Thank you
Image 899
Dear
     I confirm that the installation package has been installed successfully and is running. That could be a problem with my path Settings. path is like 1,0. What do they mean, 1 is the port number, 0 is the rack number?I added the Enternet_Ip as shown below, thank you.
Image 901
I am sorry, I can't tell you this. We are using
https://libplctag.github.io as an underlying library. Maybe you can find some more info about this on their pages. Best regards Thomas
Did it worked with just different parameters or did it only worked with the Update which I have send you?
