Geplant
HelloWindow occasionally blocks CI builds when running Unity in batchmode
Ramon Janousch vor 10 Monaten in realvirtual.io Starter and Professional • aktualisiert von Support vor 10 Monaten • 3
when we trigger our build pipeline and run tests or build the project via script, from time to time the HelloWindow pops up and blocks the pipeline run.
Context
  • We are using realvirtual in a Unity project that we build and test via Azure DevOps.
  • Unity is started from the pipeline in batchmode (no user interaction, headless build).
  • Typical commands are like: -batchmode -projectPath <path> -runTests or -batchmode -projectPath <path> -buildWindows64Player <path> ...
Most of the time this works fine, but occasionally the HelloWindow appears during startup and seems to wait for user interaction. Since this happens on a build server without UI interaction, the process just hangs and the entire CI job times out.
Expected behavior
  • When Unity is running in batchmode (CI environment), realvirtual should not open the HelloWindow at all, or
  • There should be an option (e.g. a setting, scripting define symbol, or asset menu option) to completely disable the HelloWindow for automated builds/tests.
Actual behavior
  • Infrequently, the HelloWindow still appears during CI runs, even though Unity is started in batchmode.
  • This blocks the build/test pipeline until it times out.
Questions / requests
  • Is there a recommended way to disable the HelloWindow for CI/batchmode runs?
  • Could realvirtual internally check for Application.isBatchMode and skip showing the HelloWindow in that case?
  • If there is already a setting or flag to turn this off, could you point me to the correct configuration?
Thanks a lot in advance!
Image 1447
Geplant
RE: HelloWindow occasionally blocks CI builds when running Unity in batchmode
Hi Ramon,
Thanks for the detailed report. You're right - we check for UNITY_CLOUD_BUILD but we're missing a check for Application.isBatchMode which is why it can still appear when running Unity with -batchmode for CI pipelines.
Workarounds until the official fix:
Option 1: Add DEV define to your build command (Recommended)
Unity.exe -batchmode -projectPath C:\Project -runTests ... -defineSymbols DEV
Option 2: Set the define via script before tests run Create an editor script that runs before your tests:
[InitializeOnLoad]
public static class CISetup
    static CISetup()
        if (Application.isBatchMode)
            // Prevents HelloWindow from showing
            PlayerSettings.SetScriptingDefineSymbols(
                NamedBuildTarget.Standalone, "DEV");
Option 3: Patch locally In Assets/realvirtual/private/Editor/OnPostProcessImportAsset.cs line 142, change:
if (Game4AutomationImport && !Application.isPlaying)
to:
if (Game4AutomationImport && !Application.isPlaying && !Application.isBatchMode)
Fix: We'll include this batch mode check in the next release.
Thanks for reporting!
We use version
6.2.1.7128 (Unity 6000.2.10f1)
I see that you are no longer opening the window for cloud builds (!UNITY_CLOUD_BUILD && !DEV).
It may be that it only appears in the headless tests.
We use something
C:\Program Files\Unity\Hub\Editor\6000.2.10f1\Editor\Unity.exe" -batchmode -projectPath C:\Project -runTests -testPlatform EditMode -assemblyNames Project.Common.Tests -testResults C:\Project\TestResults\EditMode\EditModeResults_20251218_171253.xml -logFile C:\Project\TestResults\EditMode\EditModeEditor_20251218_171253.log -enableCodeCoverage -coverageResultsPath C:\Project\Coverage\EditMode -coverageHistoryPath C:\Project\Coverage\History -coverageOptions generateHtmlReport;generateAdditionalReports;generateBadgeReport;assemblyFilters:+Project.*,-*Tests
I can confirm that it only pops up when I run the tests.
I also see this window (not blocking CI, just annoying).
Image 1448
Geplant
Hi Ramon,
[InitializeOnLoad]
    static CISetup()
to:
