I have done some thing as follows:
- As you can see,the picture 2 about "TwinCAT ADS Interface",I set Parameters in PLC option,such as netid=xxx/Port=501.
- The Port no.501 has so many symbols as picture 1 arrowhead shows.
- Then I new a "plc output float(script)" for get actual position about cube1-Axis ,the name = Axes.Cube1.Actpos
The problem is :
- when i click play button, the "TwinCAT ADS Interface" script feedback ADS State is "Not Connect"
- we do not connect with ADS Server about Port 501,So we can't get the symbol's data about "Cube 1 Actpos Symbol" too
Thanks for your tips about “user permission”,I realize that the problem is make by clients have no permission to add symbol or update list of subscription,So I check relative settings about permission of guest,and now,It work well.
hi thomas:
my environment is:
BEST HTTP V2 2.8.6
REALIO 2022.12 pro
I have alread finished script difinetion and TwinCAT3(Licenses、PLC Project) and TwinCATHMI configuration. But I still got those error info as follow picture.As we see , Websocket cliet has connected to Server, but it send a error message,i don't know how to make this trouble.
Please give me some ideas, i will check immediately.
some messages for you as follow,hope for your answer
if you can take a video about TwincatHMI and unity,it will work well.it is seen like your vides in your youtube channel
thanks for your suggestion,do you have any other tutorials about how should we do TwinCATHMI communicates with Unity(for webgl publish Platform).I try to read documentation about TwinCATHMI chapter,but i think there are many details be Omitted. so it is so difficult to complete my test demo.
thans about your attention ^_^
